40 hp Johnson Suntracker, oil injected, 89'
Pontoonfun
Motor starts and goes forward and reverse, however when I take it out of gear it still goes forward and reverse. Whats up with this, help!
tashasdaddy
Re: 40 hp Johnson Suntracker, oil injected, 89'
has the lower unit been off just prior to starting this problem? if not cable connections, or worn out cables.
Installing control cables.
1. set controls in neutral and at idle.
2. manually make sure motor is in neutral and at idle.
3. on the motor end of the cable, is a trunion nut (adjustment nut) there is a retainer, on
the motor for the trunion nut remove the clip.
4. without moving anything on the motor, adjust the trunion nut (turning nut) so that
The nut sits in the retainer, and will connect to the motor.
5. connect the cable to the motor, reinstall the retainer clip.
Note: you adjust the cable to the motor, not the motor to the cable.
