4000 rpm
Kyletalmadge
Does spark jump a gap of at least 3/8" or more on each lead ?----Use a test device and not the sparkplugs.------Or start motor out on lake. ----Take up to full throttle with #3 plug wire pulled off.----Repeat with #4 and then #1 and #2----Also use a STRONG flashlight and look into each carburetor bore at full throttle.----Compare fuel coming up each nozzle.-----Some simple trouble shooting and thinking finds the issue almost every time !!
Kyletalmadge
Ok cool. Thanks man. Ive never messed with spark and carbs too much so this will help a bunch. You look in the bore of the carbs on the intake side right? and when you say then #1 and #2 youre talking about one at a time right? Cause ive learned then engines have highs and low in them.
Honorary Supreme Mariner
This engine idles on top 2 cylinders.----Bottom 2 carburetors kick in at about 1800 RPM.
Kyletalmadge
Good luck sorting this motor out.
In your one comment it almost sounded like i should pull the top 2 wires at the same time. Is that what you were saying or to pull one of the top 2 at a time? You helped me alot just telling me that. That helps alot. Then you can pin point which cylinder is causing the problem
jimmbo
I just dont have the money for them to diagnose it again. With a new trim assembly, electrical parts and disnosing i have like 4k into it.. not to mention the guy who had it before me had all the electrical messed up. Horn, bilge, Tachometer, speedometer, livewell , nothing worked so he fixed all that. A 6k dollar boat is turning into a 12k dollar boat. My buddy told me to sell it and buy a new one haha
Some Buddy, won't help a Friend. The guy must have Dollar Signs in his Eyes, and a Cash Register for a Heart
Kyletalmadge
Dont disagree. He was helping me out in the beginning when he first bought the place but he has a couple different business so hes hardly at his marine shop anymore so i have to deal with his peons
jimmbo
Still, a friend would have a Note on your Customer File to indicate "Special Person, tread Gingerly..."
