402 starter fluid
rimmy
74 402 jet.It getting hard to pull start.So will a little fluid hurt the motor?, It runs great. also i found in the bottom part of the housing a 1 inch return spring and i don't know where it goes.Any help will be great
bullbat
Re: 402 starter fluid
Thats a good way to ruin a good engine. if nething get your some mixed gas in a squirt bottle and use that never use starting fluid
tashasdaddy
use only premixed fuel to spray into the carb. starter fluid removes the lubrication and burns tooo hot. it is time for carb cleaning and rebuild kits.
Silvertip
Actually, the best solution is to fix the engine so you don't have to resort to this procedure.
