40el72 Johnson electrical
Kylebellis
Got a old Johnson on the weekend it's
In decent shape turns over greats with near perfect compression, but I have a few questions about wiring my specific year isn't in the wiring guides offered here... There no spark.... What is the small switch under the flywheel
That looks like a square button, the wire
Was totally corroded . Also would the main harness have some thing to do with it if a post inside the male plug was loose? Thanks alot
Kylebellis
Re: 40el72 Johnson electrical
Anyone?
tblshur
good morning Kylebellis, you might look at the Sticky files at the top of this page it has wiring diagrams.
Kylebellis
Thanks for the reply, but as i said there is no wiring
Diagram for 1972 Johnson 40 hp electric start....
boobie
You might look for an OEM factory service manual.
