40elpt Mercury 40 hp
tblshur
Need a diagram for tale tale hose it is stopped up somewhere
tblshur
Just an explanation would be good from the discharge I can trace back to I think fuel pump then it goes down to bottom front of motor can’t see without moving a lot of stuff I blew on that hose it did blow something out but don’t know where and it comes back when motor is started thank for any help:joyous:
mgjtkt
I'm not sure what you mean by "tale tale" hose. Look on a parts diagram for your motor ( you can find that on this site) and show us what parts you are asking about. Also, get us the serial number to help
tblshur
Pee tube pees water out back of motor to let you know that water pump is pumping thanks for your reply
mgjtkt
Run a piece of weed whacker line up into the hose, bugs build nests there.
