40hp 4cyl carb adj.
supersoaker548
hi guys i just pickup a tracker with a 96 40hp 4cyl 2s OG313850
it has been setting for a yr or so and was hard to get started so i pulled the carbs and cleaned them :joyous: both had a small amount of trash in them.
the carbs are WMA-2 3330-830281-C
there is a rod from one carb to the other to work them together, on the bottom carb there is an adjustment how do i readjust this ???
i need to know how two adj. A/F and Sink them
did a comp. test and all cyls 130-135
Thanks Don
supersoaker548
Re: 40hp 4cyl carb adj.
the carb in the link is diff.
i found the sticker that someone taped in the maintenance manual Model # 1040312SN 19 / 43 Tracker 40ELO 1996 06/29
you have a pm
i have a seloc manual but it doesn't show my setup:(
supersoaker548
haven't forgot ya
had to order a part should be here this week
supersoaker548
Thanks Gerry got it running today and all set sounds and run's good
i do have a water problem that i will make a post about
