whiskerchasin
Thread starter- Joined
- Jul 25, 2011
- 45
I obtained an 85 40hp Johnson J40elc0. After removing the VRO pump I installed the non-vro fuel pump from sierra. Pumped the bulb tight and cranked it up.With the manual primer valve in the manual start position it fired right up for about 1 second then died. It done this 2 or 3 times, i don't know what's wrong with it. It doesn't slowly die it just shuts right off.
It may be electrical because it does not have the original omc controls on it, that was attempted to be installed by the previous owner. The controls are taken apart with the ignition hanging out of it with ground wires exposed and twisted together. I'm in the process of getting some omc controls (dang they're not cheap) so maybe that'll help.
any help is greatly appreciated, Thanks.
