40hp gale
ckremer
i am looking for something to extend the shaft, right now it is ok for 15" i need 21" for it to work on my boat. does anyone know or have repair parts for this motor, the boat shop said it is mid 60's
WillyBWright
Re: 40hp gale
It would be early to mid 60s. Johnson and Evinrude parts will fit, but not from their 40s. Those have different gearcases. But old 25s, 28s, 30s, 33s, and 35s use the same gearcase as yours. Those extension parts will for your Gale. You'll need an extension for the midsection, a longer shift shaft or an extension link, a longer pipe for the water pump or an extension piece, and the killer ... a longer driveshaft. The only thing that can't be extended is the driveshaft. You have to have the right one. Many dealerships keep a pile of used motors somewhere. You might start checking those.
JB
Re: 40hp gale
These people have warehouses full of used engines, CKremer.<br /><br />www.twincityoutboard.com<br /><br />You will need the model number of tour engine to ensure compatible parts.<br /><br />Good luck. :)
