pedroofn19
- Joined
- Oct 18, 2004
- 41
hello I have a 1993 40hp mariner that starts well untill the throttle is pushed forward and then it stalls. If i lift the warm up lever a little it will go into gear and run fine, and then i can push the warm up lever back down once the boat is moving. But as soon as the engine has been put into neutral and into gear again it will stall before the boat starts moving unless the warm up lever is raised. The engine has had a full service recently, and runs fine apart from stalling. The engine starts well and goes into gear fine when it is out of the water and has the muffs on. I dont know much about engines so any help would be much appreciated.
Is this just a case of the engine not having enough revs once put in gear?
Please help.
Please help.
