40hp rebuild
hardly
1993 40hp I have been told I need to have it redone may cost $2000. I see here I can get a new powerhead for $1745 my ? is how hard is it do the swap? I found a co. in PA. that will do it while you wait but its 5 hr. from me..
steelespike
Re: 40hp rebuild
Couldn't you replace it for just a little more.I see here at iboats they are selling low hours 2009 4 stroke Yamaha 40s for $4,100.
Les Robb
Re: 40hp rebuild
Bear in mind an easy rebuild can turn into a nightmare. Personally I feel a new short block is the best route to go. (Well, really new engine would be better if affordable) Lot's of pro's and con to consider.
Best of luck
Faztbullet
Re: 40hp rebuild
If you mechanically inclined you can rebuild it cheaper than $1700, I looked thru catalogue and new pistons,all bearings,gasket set & seals,impeller and new VRO/OMS pump will only run around $800. If it need boring add about $100 to price plus $65 for service manual. So the most you should spend is $1000 if you do it yourself unless crank is bad. I would remove it and tear it down to see exactly what it needs as you may can get out cheaper if it only needs one cylinder repaired.
hamburgerman
Re: 40hp rebuild
I had a guy at the shop tell me that once
all i needed was rings and a head gasket 47.00 thanks to this fourm I did all the work myself and it never ran better dont always listen to what someone else says. post what your motor is doing so we can help
