454 7.4L mystery fasteners on back of engine block
CayugaCobalt
What is this? and is it supposed to be sticking up like that? I cannot tighten it down,IMG_8969.jpg
dubs283
Rear engine mount bolt
Yes, due to the spacer
If it's tight, it's tight
You should tie the sender wires out of the way as not to interfere with the steering actuator nor rub on the coupler
When was the last time the alignment was checked?
Those rear mounts look like the bushings collapsed
CayugaCobalt
Thanks Dubs: That is the answer I was kinda expecting but wasnt sure.
CayugaCobalt
How often or when is one supposed to do the alignment check? What are the symptoms of mis-alignment? The bushings I see around the bolts are standing up, not collapsed. Sorry I dont see whay bushings you refer to.
Per the manual you pull the drive every 50 hours or annually to check alignment, gimbal bearing, U-joints, bellows, etc
