454 and alpha 1 drive
ringmaster
i just got a boat given to me its a 1978 formula with a 454 and a alpha 1 outdrive. this is a matching set but i dont thing its origenal to the boat. how well does the alpha 1 hold up to the 454's?
Don S
Re: 454 and alpha 1 drive
78 was way before Alpha drives. The 454 with an alpha was for only 86 to 88. It was not the best idea, and in 88 the Bravo drive came out.
ringmaster
im putting the motor in a 26ft sea ray and i do want a bravo. im looking at a bravo 3 is this a good choice?
jaxnjil
well ringm; i hope so. i'm swaping my alpha drive for a bravo3 in our "88" 230 sea ray weekender
don told me this could be a problematic combination when i bought it. i thought as, i was using it at higher elevations i would loose enough horse power i could get by. i found out i was wrong and he is right
HT32BSX115
Howdy,
For a large "cruiser" type boat, A Bravo III is probably your best choice.
You'll want either a 2.0:1 or 2.2:1 drive. You will also need to obtain a Bravo gimbal and associated hardware.
What was in the boat?
Cheers,
Rick
ringmaster
i believe a 350 im not sure my local marine mechanic gave me the sea ray its a 1980 and in excalent condition just needs a motor and out drive. i figured since i have a working boat now i can take my time and get all the parts that i need to do it right. its a 1980 sea ray 26ft with a aft cabin. what gear would be the best for all around performance the 2.0 or the 2.2?
Don S
If you want to stick with Mercuiser.
