454 bravo backfires when hot
jeffssgtusmc
New motor, coil, wires, plugs, ign sensor in distributor. Motor idles like a champ. Runs good for about 45min then all it will do is idle anything over 2500 rpm it spits spurts and backfires. At one point it would not start so I moved the timing to get back to dock. Im thinking the ign amp might be getting hot and not working right or else fuel is boiling in. Carb. Any thoughts? ??????? Im lost here. Thanks for reading
Re: 454 bravo backfires when hot
H e l p!!!!!!!!!!!!!!
Ayuh,... She's goin' Lean Captn'....
Clean/ sort out the Fuel Delivery system, whatever it may be...
Start by checkin' the Contents of the Filters...
jeffssgtusmc
Wouldn't it hesitate when its not hot also.
