454 distributer/timing problems
rthomas
Hello, my port side 454 has been running like crap for a bit and I've chased it down to the distributer (Tbolt V large module 1984) when I put a timing light on it its all over the place, this results in a jumpy idle and an occasional backfire at speed. is this likely the module itself or the pickup in the distributor itself?
Being a 1984 it would be a TB4 unless its been changed
That said, I would look at the distributor cap, rotor, wires and then pick up in that order.
Look at link 21 from this sticky
achris
More fish than mountain goat
Make sure you have the distributor body, the sensor and the module properly grounded. (with a wire, not just bolted into the engine)
nola mike
Check that the distributor doesn't have any play, worn bushings can cause erratic timing.
rthomas
well I think Ive figured it out, when I pulled the module off of the riser to find a part# (not legible) I saw that the resin filled backing had a hole in it, not sure from what. now the challenge of finding a new one, mercruiser has a kit to upgrade the module to basically a T5 (part #15248T02) but is not currently available and sierra doesnt make one either. With that in mind if I cant find a used one I might look at upgrading to a set of Davis Unified Ignition marine distributers, these are basically based on GM automotive HEI distributers, has anyone ran these?
If your "Sure" the module is bad, then I would suggest Delco EST over the DUI
Just my opinion, others will vary
DUI is iffy. have never found where they actually tested to SAE J1171
I would go voyager over DUI. I myself am running a Mallory YLM 624 as I needed/wanted the ability to adjust my timing curve.
