454 Electric Fuel Pump
20pilot
Can someone identify this fuel pump. It is off of a 33' Tiara with a 454. The only number on the pump is 2143130A. I have attached a picture of the pump. Is this a sierra part, or something I should get at the local auto parts.
HT32BSX115
Howdy,
Hard to say without knowing what exactly you have. Is it a Mercruiser, Volvo or OMC?
What model number is, are they?
That fuel pump looks like several different ones including Sierra.
You might be able to get it at an auto parts store (like Napa) that can order marine parts
Regards,
Rick
Ayuh,..... Welcome Aboard,.... Is yer 454 Carbed, or Efi,..?? 'bout what year,..??
Got it's serial number,..??
It ain't an automotive part,...
20pilot
This is a used boat with rebult engines. I am assuming they are crusader engines, but can't be positive. I have not been able to locate serial numbers but I am assuming they are from either 1995/1996, 454 carb'd engines.
HT32BSX115
That pump appears to be a Carter P60905
You can get it directly from Rock Auto for about $60 + shipping.(If you buy it from any marine supplier, you'll pay 2 to 3 times that price.)
CARTER Part # P60905 More Info Crusader Marine 454/7.4L 1992-93; Crusader Marine 502/8.2L 1992-93
Category: Fuel Pump
I like this pump! I am going to use it on my 1955 Ford truck project! I might even put one on my 1997 Mercruiser 454 so I can get rid of that problematic Bravo raw water pump with the mechanical fuel pump on it!
Ayuh,... That's the Same fuel pump as on My '93 Merc 4.3LX,....
Fun Times
Any photos of your engine you can post? Someone may recognize something to help. Might be worth a shot.:)
