454 King Cobra Omc Reverse Sense Rotation
mick750
HI
I HAVE A PROBLEME WITH MY ENGINE OMC KING COBRA
ELECTRICAL PLAN OF SYSTEM IGNITION SPITFIRE SENSOR OF DETONATION
I HAVE NEED OF THE ELECTRICAL PLAN OF SYTEME FIRING OMC 454 IGNITION SPITFIRE SENSOR OF DETONATION ...
WHAT THE AVANCE TIMING FOR THIS ENGINE OR V8 BIG BLOCK
http://rides.webshots.com/photo/2983948370101354590yXOdmT
I HAVE A PROBLEM WITH MY ENGINE OMC KING COBRA I TO PUT OFF THE MOTOR SOMTIMEMOTOR REVERSE AND WATER IN THE CYLINDER
WHY ??
I NEED HELP PLEASE
SORRY I SPEAK FRENCH AND LITLE ENGLISH
Don S
Re: 454 King Cobra Omc Reverse Sense Rotation
Here is a service bulletin that should explain the water in the cylinders.
http://www.boatfix.com/merc/Bullet/01/01_13.pdf
Hi idle and improper timing are the most common cause of the engine running backwards when you shut it off (dieseling)
HT32BSX115
Sorry about your problems,
1. Find someone who reads English.
2. Your 1989 may be a 1990 model (PWS) . I think the 454 came out in 1990.
3. Have him/her do a search on US EBAY for a service manual for a 1990 King Cobra. EBAY user "SEARAYMAN13" always seems to have OMC manuals (I got mine from him)
4. You may have to switch to a distributor system for ignition. The Spitfire ignition system for the King Cobra may be obsolete. Check with Doug Russell Marine or BRP for parts
Good luck.
Rick
mick750
J SHALL LIKE TO BUY A KIT IGINITION MSD OR OTHER WIRE AND COIL
REPLACE DISTRIBUTOR INEVITABLY? FOR replace spitfire system
what to choose iginition for this motor :confused:
PERFORMANCE INCREASE WITH AFTERMARKET IGNITION :confused:
HOW WIN A BIT HP FOR THIS MOTOR ? BIG CARB ... ?
A
ND WHAT MAX RPM FOR THIS MOTEUR:confused:
454 omc king cobra
THANK YOU
MICK
Ayuh,....
Aftermarket Igntion usually gives Better Starting,+ Running,.... Not more Power.......
Inital Timing should be around 8?/ 10?....
The Horsepower is/ was probably 330hp.... Max rpms would be 4400/ 4800rpms.......
HT32BSX115
Mick,
MSD might be ok or any after market ignition. I don't know if the after market systems use a detonation (knock) sensor though. I don't think you should run without a knock sensor. You could cause engine damage is the engine is allowed to "ping" or detonate and you may not be able to hear it when it happens.
It might even be possible to switch to a Mercury Thunderbolt V system. (which does use a knock sensor)
The ignition control system actually retards timing when knock or detonation is detected.
You also have a shift interrupt system (not an Electronic Shift Assist) that might work well with an after market system.
Regards,
Rick
mick750
Ayuh,....
You're trying to Fix a Dead Horse,......OMC is Dead,+ Gone....
Either of those manifolds will bolt to the motor,.....
Getting the end of the riser to line up with the rest of the plumbing will be the Problem that you'll have to get around.....
