454 mag mpi oil pressure sensor location
rusty12
I am having an issue with the needle on my oil pressure gauge not dropping back down after the rpms are increased but when i shut the boat off and restart it drops back down. I am picking up a new sensor tomorrow. Can anyone give me any information as to where it is located on my engine.its a 454 mag mpi inboard
Thanks
Ayuh,..... Welcome Aboard,..... On a Chevy V-motor, it's either down low, aft port side, just above the oil filter boss on the block, or just behind the distributor, on the block, at the edge of the intake manifold,.....
I'm thinking you mean "decreased"
Don't see it being your sender, think its the gauge
rusty12
Yes sorry I meant decreased. You think its the gauge more than the sender? Maybe I should try a gauge first
The gauge is powered when key is ON. The gauge gets its reading from the sender. So gauge needle goes up and hangs, and does not go down at all until power is turned off.
I don't see it being the sender
Could test, find the sender and remove the wire when running. If it drops down then could be the sender, but if it doesn't then no. The gauge sender is a bit larger so should be easy enough to find. As Bondo mentioned it should be down low port side where the filter or remote filter attaches
