Hello,
I have a 1999 454 Magnum Engine that I'm tearing apart to try and fix. The motor only has 35 hours on it believe it or not.
I removed the heads and found cylinder 2 had a bent exhaust valve and a crushed pushrod. The piston also had a nice ding it from where it hit the valve.
I dont have the tools or capability to pull the motor out of the boat so I'm asking if the piston is still safe to use. I know the internals are forged being a MAGNUM engine so can I safely get away with not trying to replace that piston?
The cylinder walls are good.
Heads look good besides that one valve and some scattered rust corrosion all throughout. The engine was damage and then sat for about 4 months. I just bought the boat. Owner was not really sure when or how it was damaged.
It appears water leaked from the exhaust elbow into the engine. Although I'm surprised that is the cause for the bent valve because it seemed like a small slow leak.
