454 timing w/ prestolite ignition
ob
Re: 454 timing w/ prestolite ignition
mechanical or vacuum advance?
denniz
8 degrees. If you have vaccum advance you dont have a marine distributor.
ob
9-10 degrees before TDC.on vac advance .Each engine and load condition dictates the final setting.I'd start with 9.
captianwh
OOps, brain not engaged... It is a mechanical advance. What RPM do I set the timing at???
ob
Then as Rod Knocking states at 8 degrees BTDC.850-900 RPM's
