outdoorsman10
- Joined
- May 14, 2010
- 73
So, I thought as long as it's cold and miserable out, I would start tearing down the lower end of my '76. Should be simple, drop the 4 bottom bolts out and presto...NOT!
Ok, pull the prop and shaft out THEN the leg will drop.....Wrong again! Shaft, bearing and pillowblock won'tcome off. AAHHH!!! What if I remove the screw pin from in front....Still nothing!
Here it is, pulled bolts out and leg dropped 2 inches and thats it. Is there something I'm missing????
Been to broke/lazy to get a repair manual. Can someone give me the heads-up on what I should be doing?
