natemoore
Thread starter- Joined
- Jun 13, 2009
- 844
Uh...is it normal to see gas dripping down from the venturi into the intake manifold just after the engine is shut off? I'm thinking not.
I double-checked the float level and float drop settings, then blew into the fuel inlet side of the float chamber to verify that the valve would shut off fluid flow. All seemed okay.
The engine would run like a top for a few minutes then just die. I am fighting a bent pushrod problem which could cause the dying, but the fuel dripping into the intake manifold after shutdown is troubling.
This is a Quicksilver remanufactured carburetor, BTW.
