dieselram94
Thread starter- Joined
- Apr 14, 2010
- 94
Ok, pulled the drive off this 1987 Larson alpha one with a 470 mercruiser. I changed bad gimbal bearing and seal. I believe the water in the bellows lead to it going bad...lol! I just purchased this and was told it sat tied up to the dock two years ago, pulled out last summer and previous owner heard the bad gimbal bearing and just didn't use it as a result. So it's been two years since being used. Three years ago a head gasket was installed. After inspecting bellows for cracks I discovered the water hose is mostly kinked off and deteriorated at the kink with the belting showing. I know these motors are sensitive to getting hot so naturally I'm a little nervous of the head gasket. Oil is clean with no coolant in it. Antifreeze is down some but I attribute that to the very slow drip from water pump seal at the cam.
I'm going to obviously change the bellows and water hose but am now wondering if I end up doing gasket how often do these 470 blocks warp? Or pull threads from head bolts? I really don't think I have a head gasket problem but I just get ocd about things! Lol
