470 compression
hadaveha
Can you check the compression on a 1984 mercruiser 470. With the exhaust manifold removed, and if you can what numbers should I be looking for
Ayuh,.... The manifold don't matter,.....
150 psi, 'n above is a healthy motor,....
Below 150 psi, the motor is at varyin' degrees of gettin' Tired,.....
At 100 psi, it's no longer a runnin' motor, but a rebuildable core motor,....
