Hello all, if you have watched my posts. You know i have the worst luck with engines. This time around, port was slightly overheating at anything over 1500 rpms. The exhaust manifold turned out to be leaking exhaust into coolant. So I replaced the exhaust. And guess what, nothing changed..... So far, new heat exchanger, thermastat, hoses, exhaust manifold, new riser, plugs, wires, rebuilt carb, reset timing, replaced impeller. I swapped drive hoses and starboard still holds it temp running off the port drive, and the port still heats up running off the starboard drive. Oil and coolant are clean. Flushed the engine side and plenty of flow. Anyone got an idea what could be up this time? Is it possible for maybe a headgasket failure that is letting exhaust into coolant without contaminating the oil or coolant? Pressure tested for a cracked block, no leaks. I am lost, and so is the mechanic. Nothing like spending a few grand and still have the issue. I said I was going to sell this thing, but I have not had both engines running for 3 months now.
