470 cylinder head re-torque SCREW-UP?
natemoore
I was re-torquing the bolts on my cylinder head last weekend. I turned the first bolt about 1/16th of a turn before I realized that I was going the wrong way (too much sun, I guess):(
I immediately corrected and re-torqued to 130 lbs-ft and proceeded with the rest of the bolts in the proper sequence. The engine was absolutely cold, btw.
I figure I'll go through another hot-cold cycle and re-torque that bolt.
Am I okay? Not looking for crystal balls, just educated guesses.
Yeah, yeah, I know LEFTY-LOOSE RIGHTY-TIGHTY!:p
Bifflefan
Re: 470 cylinder head re-torque SCREW-UP?
If you were just checking the head bolt torque and looseded one, you are fine.
At first read i thought that you had taken loose bolts and tightened them to 130lbs one at a time. Then you would be in a different situation.
natemoore
No, no. I was beginning the re-torquing sequence and was discombobulated momentarily. Only loosened the first bolt enough to realize I was going the wrong way...about 1/16 of a turn. Then I corrected the mental error and continued on with the sequence.
I ran it today. It ran great. The last time I was this proud was when my last child was born--no wait--after I completed my first scratch-built guitar--no wait--after I finished the man-cave...you get the idea.
stonyloam
OMG on a 470!!!!! STAND BACK SHE'S GONNA BLOW!!!!!:eek::eek::eek::D
