riskibusiness
Thread starter- Joined
- Nov 27, 2011
- 129
how can I be sure that water is pumping through the exhaust manifold?
exhaust boot cracked but almost looks melted I might just be being paranoid.
Ayuh,.... Ya probably oughta get a new set of shutters too...
If that rubber coupler is burnt up, No doubt the shutters are too...
The shutters can impede the water/ exhaust flow out the drive...
the coupler popped or burnt
so if the exhaust boot goes out or pops off or whatever the impeller stops pumping or it just cant draw up that far without the exhaust pulling it through ??Aaha! When your coupler popped your raw water pump stopped, so there was no cooling water to the exhaust, so you probably did overheat the rubber stuff. If the shutters are missing it would probably be a good idea to look for them in the exhaust. It would still probably be a good idea to at least take look at the impeller housing, if it looks OK your impeller should still be fine since it did not run dry. You can probably reuse the gear lube in the outdrive if it looks good since it has been in there for a short time, but you should replace the gaskets on the oil drain and vent plugs. Good luck
