natemoore
Thread starter- Joined
- Jun 13, 2009
- 844
I was putting the impeller back on today when I started having self-doubts about it touching the front cover on the back side, so I took the impeller off again to get another look at the backside of the impeller and the inside cover.
Then I noticed some aluminum powder on the threads. Apparently, I misthreaded the impeller even though I started it by hand and it went on straight.
Now I can hand tighten it all the way on without the torque wrench.
1) Does this impeller rely on tapered threads to keep it tight on the stud?
2) This is a $70 part. What do you think about the idea of me using a large round punch to slightly bend the last three threads of the impeller to create some friction, then using Loctite 271 (red) for added measure?
The manual says use no Loctite on the impeller, but I'll worry about that if/when I ever have to take it off again.
The manual also specifies 15 lb-ft of torque, so apparently it doesn't take much to keep the impeller snug on the stud.
