85imperial
Thread starter- Joined
- Mar 2, 2010
- 11
Finished rebuild, engine on pallet in the garauge. Filled fluids, running fuel line from gas can, battey hooked up, mech oil guage installed in line with elect sensor. Crank engine over and it just cranks. Put a little fuel down the carb and again just cranks. After a few times I did get a bang-pop from the exhaust riser, but engine won't run. Am I missing something? What would cause this? Does the fuel pump need to be primed? Cranks over fine but will not run. 170 hp 2 barrel merc carb. Firing order 1342 clockwise on the wires. New wires, points cap coil ect. Getin spark to the plugs. Could I have the distributor 180 off? 1&3 are down towards the oil pan vs up towards the valve cover. Marked and took pics before disasmebly, to make sure it went back right. I want to get it runnig prior to getting it installed in the boat.
