nemyarbretlaw
Thread starter- Joined
- Oct 18, 2009
- 4
I have a 470 Merc that I bought in a 19 foot Renken from a guy not knowing of the dreaded front seal tendency to leak. (I am new to boating) After it was too late and I had bought it, I figured the front seal was leaking and I would have to R and R it. I bought a radiator pressure test kit and put it on just to be sure. What I found was that many of the hoses were loose and leaking. I tightened all of them, I put 16 pounds of pressure on the system and it never moved for 20 minutes. Do you think it was just the hose clamps or can a leak or blown head gasket not show up until higher pressures? The owner before me said it was getting warm and he pulled it out of the water. I found pieces of the impeller in the exchanger so that is why I tried a pressure test fearing a head gasket. Long story short, I bought two boats on auctions and will sell one so I am hoping this can just be serviced and sold. It has the original charging system, 4 inch exchanger and has not had the front seal done. Serial number is 6379025. The other boat is a merc 3.0 and does not scare me as much as the opinion of the 470's. What do you think. Thanks for the help.
