470 timing advance direction ?
Rake722
Hi all, had an issue on the water with hard starting in neutral and wanted to check timing.
I had no light but rotated the distributor anticlockwise about 5 degrees and she is more responsive and idles better.
Is anti clockwise rotation of the dizzy advance or retard please ?
Does winding the idle screws out richen the mix or lean it ?
Thanks
Ron
Don S
Re: 470 timing advance direction ?
Get a timing light...... before you destroy your engine.
Mixture screws- out richer, in leaner.
Rake722
Thanks Don. Plugs now look sooty so on to that.
I was under the impression one could time these by ear but am unsure if I have advanced or retarded the timing so wanted to know.
I have a timing light and dwell meter in one so will do it with those soon but just for info really
Thanks
Ron
Don S
Not if you don't know EXACTLY what you are doing, and then it's iffy. Burn some holes in your piston and see.
stonyloam
The distributor (rotor) rotates in a clockwise direction, so by rotating ANTICLOCKWISE you ADVANCED the timing. Yeah as Don says a timing light is a necessity and a dwell meter if you still have points.
Rake722
Thanks both of you.
Timing light and dwell meter packed in the truck ;0) who needs detonation ! Not me.
