Re: 470 timing cover
Well the impeller was off about a half hour after I posted that, thanks it's the new style impeller guys, but the stud seems to be "frozen" in the cam, or part of it. From the article I saw it's not right, or is this misleading Eric / Stony? Help me narrow this one down guys, will post pics later this evening. I used
an impact on it to get it off but only to loosen it nothing more. Inspected the threads and they seem to be good, put some wd on em and spun it a few times then removed it and set it off to the side. Now the other issue....the stud. Will it come out we'll have to see. Once I reinstall this stuff at the end is using red loctite the way to go or use the blue, or does this depend on the location and function?
Today I hope to get the gimbal off and the rest of the bracketing and hopefully not run into anything but Murphy might be lurking around so you just never know.
