485 Mercruiser over heating.
Landon
I have two 485 mercruisers in my 1980 wellcraft nova 250. My one engine starts overheating after about 3-5 minutes of running it (goes up over 200f). If you run it faster the temperature goes down a bit. I have replaced the impeller (it was completely burn out), removed the thermostat, flushed the cooling system and changed the coolant, and it still over heats. Im not sure what could be causing this any help would be appreatied :)
HT32BSX115
Re: 485 Mercruiser over heating.
Howdy,
Welcome aboard.
It sounds like the impeller failures may have send fragments into the heat exchanger..... restricting raw water flow through it.
Your riser and manifold may be running hot too.
Landon
Howdy,
Welcome aboard.
Thanks for your help
stonyloam
Look for impeller pieces under the front cap of the exchanger.
