roffey
Thread starter- Joined
- Nov 22, 2012
- 2,206
I have a 488R (3.7 merc) with a closed cooling system. I am putting it away for the winter. I checked my owners manual and all it asking I do is check the antifreeze to make sure it's at the right level. With my other I/O I had to run antifreeze through water muffs.
What I did for the out drive was grease where I could, remove the prop and put the out drive in the down position and blow air through the drain holes in the drive. Should I do more? I know there is stuff still to do on the motor.
