chris16371
Thread starter- Joined
- May 19, 2017
- 156
It's been awhile since I've posted, I've come a long way since then but I could use some advice and remembered the forum was a great resource so here I am.
Sea Ray boat with a 496 HO was towed off the water, owner said it sounded like a bunch of nuts and bolts were bouncing around the motor. I checked the oil, only 1.5 quarts were in the engine. I put proper amount of oil in and started engine, sounded like the customer said. I thought it dropped a valve but now I think something else. I pulled the plugs, all looked lean which I figured they got hot from lack of lubrication in the motor. I did a compression test, good across the board. I removed belt and turned crank and didn't hear or feel anything abnormal. Source of oil leak was a bad seal on the oil filter.
I've only done basic maintenance items on the 496 HO, don't see a lot of them on our lake. I was wondering if anyone had any thoughts, ideas, tips, or tricks before I start tearing things apart. I appreciate it, thanks!
