Hatchman
Thread starter- Joined
- Aug 20, 2010
- 21
Hello, need some help please. Boat is a 2005 Sea Ray SLX 270 with Mercruiser 496 HO 425hp and Bravo 3 and boat also has fresh water /antifreeze cooling.
Tried to start the boat yesterday. Water pressure showed .6 psi while on the hose, so shut it down and put it in water to see if that would help, water pressure was only 1.0 and got an engine alarm. All Smartcraft gauge info showed engine OK, temp OK, oil temp OK, oil pressure OK, basically all the gauges were OK except for the alarm.. Shut it down raise the hatch and seems the exhaust was pretty hot, so the alarm was probably due to the exhaust temp sensor. Hopefully shut it down before any exhaust damage.
Do you think it is the impeller? What is the part number Good place to buy it?
EDIT: Engine Serial number is OW345078 and think I found the part number for the impeller
Mercruiser Brass Sea Water Pump Impeller
PRICE: $28.91
Part #: 47-862232A 2
And housing if it is scored:
HOUSING-IMPELLER (#46-862914A13)
PRICE: $249.91
Part #: 46-862914A13
Would it be better to change out the whole sea water pump? Part number?
How hard is it to get to and how long should it take, what tools will I need?
Marine quoted 600 bucks to change out the impeller and an extra 750 if it required the entire sea water pump and extra on top of that if the heat exchanger had to be back flushed to get out impeller bits, so this could run over 1500 for replacing a 35 dollar part. Sound high?
Thank you for the advice! My search skills are killing me, when I try to search for info I get 500 threads, and they seem to only have one word I am searching for and not sure if the parts I am finding online are right for this boat.
Thank you for the help!
PRICE: $28.91
PRICE: $249.91
