matt167
- Joined
- Sep 27, 2012
- 4,460
I'm preparing for a decent day or 2 of cruising a small lake and connected river, as at least one time in the water. So I have a Seahawk 3 with it's 1.5hp max capacity, but it's on their mount which they list as 3.5hp max capacity..
I have 2 outboards to choose from.
A "3.6hp" Hangkai with only it's break in hours on it.. The engine itself runs good, but it uses a Honda Weedeater clutch and an copy of an old Yamaha 2hp leg. It moves water in the barrel, but not sure about 5 miles up river. I literally bought the motor to see how bad they are.. The actual output is around 1.5hp and the unit weigh's 12 lbs.. This is the size motor that the boat should have
Also have a 1997 Evinrude 4. Runs minty, although I put a different carb on it and it will only run from it's internal tank.. Considering this one only because I know it will keep on ticking. It's no heavier than a Johnson 3hp or so being a modded version of that powerhead, but it has a spring gear shift so I could idle it down the river and it's a quiet twin cylinder
