Silvertip
Honorary Supreme Mariner
- Joined
- Sep 22, 2003
- 28,772
Re: 4stroke making oil
That is NOT what I said. I said an incorrect prop (one with too much pitch) is lugging the engine. That means it is lugging REGARDLESS what rpm you are running. Your engine has one gear -- not multiple gears like a car. That gear must get the boat out of the hole, on plane, and not over-rev or underrev (lug). The engine manufacturers have an RPM BAND they want the engine to run in. That is determined primarily by the prop installed. Engines over about 40 HP are not even shipped from the manufacturer with a prop because they have no idea what boat the engine will be installed on. A pontoon for example takes a very different prop than a light V-hull. Step one in diagnosing the making oil issue is to make some WOT runs with what you consider an "average" load. Note the WOT throttle RPM. If it is higher than the manufacturer recommends (normally around 6000 rpm) then you have too little pitch and that would not be the cause of making oil. If the engine does not get within 300 - 400 rpm of the upper end of the band, you have too much pitch and a different prop is in order.
Regarding continued operation at WOT is a no-brainer. Run continually at WOT and the engine will not run as long as it would if run at 75% - 80% throttle. The engine must still turn the same number of times to reach a destination regardless of the throttle setting, but an engine (any engine) is under less stress at part throttle than it is at WOT throttle. Your engine is designed to run at 6000 rpm. If it wasn't, the manufacturer would have specified a lower number. The manufacturer also has installed an electronic device called a "Rev Limiter". If the high end of the band is specified at 6000, the rev limiter would be set for about 6400 at which point the ignition is interrupted to prevent reving higher than that.
So silvertip what your saying is that it's ok to run a 4stroke at the high end of the rpm range safely on long runs?I keep reading in a ton of forums were people just say that 4strokes are not built for running hard for long periods of time,IMO i just can't believe that to be true.You should be able to run that thing as hard as you want as many times as you want without any issues as long as you stay under the max rpm range.If thats what helps from making oil then that solves one issue.
Now when you mean over propped,for instance i'm going to buy the brand new 20hp 4stroke suzuki efi,it's propped with a standard 10pitch prop,my boat is say 190lbs,me at 270,friend is 200,motor is 97lbs,all gear maybe 50-75lbs, so the boat has a total of say over 600lbs with a 10pitch prop,just in you opinion do you think i will over rev the engine?Do you think i may need to go with a 11 pitch prop,thats not alot of weight for the motor to push.I know i need to prob get a tiny tach but i just wanted some opinions also on this.
