i have checked everything cleaned carbs 3 times, good comp. good spark, fuel, I tried sea foam. Still nothing i took it to the lake this morning and under a load it starts to jug imediatly
Have you done a compression test yet? Could be a weak cylinder. Also, hook a timing light to each wire when the engine is under a load and see if you still have spark..
If you have spark but the plug is still wet, it may be a fuel pump problem. The pulse line is connested to #4. If the diaphram is leaking it will flood #4.
If the plug is dry all the time -- like new & dry -- then it's a fuel delivery problem. Either fuel isn't getting thru the carb or the piston is pulling air from somewhere rather than pulling fuel.
