Flynny
Thread starter- Joined
- Jul 22, 2011
- 86
I'm looking into purchasing a 2001 Sea Ray 240 Sundancer with a Mercruiser 5.0 EFI. The boat itself is in great shape and I'm ready to pull the trigger, but there's something going on with the engine. The owner blew the head gasket in the original engine last season, so he put in a new longblock, new oil pan, transferred over the 2-year old risers and manifolds, and transferred the original intake. He put about 30 hours on it after this rebuild.
The engine starts up and idles fine. It picks up great and returns to idle perfectly, as long as you don't pick it up past about 3000RPM. If you bring it up to 2700-3000RPM, let it run there for a minute, and then bring it back to idle, it drops well below normal idle speed, almost stalls, picks itself back up to 1500ish, nearly stalls again, jumps back up, and then stalls. I can prevent this by manually giving it more throttle, but it's really not an issue I want to deal with on the water. When it gets near stalling, you can hear an air "whoosing" sound, like a valve opens trying to pull in extra air.
So far I've confirmed it's not a fuel issue by replacing the water separator and running off an external tank. The fuel looked good, but I wanted to rule it out as an issue anyway.
I've read many posts about bad Idle Air Controllers (IACs), but I'm not sure if that's the issue here, because it will idle just fine if you slowly bring the throttle back, or don't rev it as high. Then again, it is original, maybe it's sticky?
The current owner has other interested buyers, so he's not interested in trying to fix it himself. I'm just wondering if this sounds like a simple issue, or if there could be something seriously wrong with the rebuild. The owner said this never happened on the water last season.
