5.0 GXi-F Injector Plugs on Wring Injector
RMassa187
Hello. I repowered my boat and now I'm not sure if I have the injector plugs on the correct injectors. Its a 2006 5.0 GXi-F EGC engine. I can't locate a wiring diagram to determine the wire colors. Can anyone help?
the diagram is in the factory service manual for the EFI
Unable to say for sure about the GXI-F but the GXI-B and C are batch fired (4 injectors fired together). The early Merc with 555 ECM was also batch fired. Later 555 went to semi batch (2 injectors each)
All of the injectors should have a one wire which is all the same color. How many other colors are on them?
muc
"Retired" Association of Marine Technicians...
T/LBL Injector Driver cylinder #1
GR/BL Injector Driver cylinder #8
T/GN Injector Driver cylinder #7
GR/O Injector Driver cylinder #2
GR/Y Injector Driver cylinder #6
T/BN Injector Driver cylinder #5
GR/W Injector Driver cylinder #4
T/Y Injector Driver cylinder #3
kd4pbs
After building this '03 Gi, I can't see how this could be miswired. The harness pretty much allows for only one way to be connected.
