kschnebly
Thread starter- Joined
- May 15, 2013
- 64
I had posted last week about my 1990 Four Winns not staying running unless the starter was engaged. Before everything on the Forum got deleted several people had given me some pointers on tracing down some problems. I found that the Coil POS connection was only at 4 bolts. After much tracing and checking I believe that it was the main engine harness not making a good connection. I was able to get 12 volts to the coil but unfortunately I checked it again later and it was back down to 4 volts. When it was 12V it started and stayed running without the starter. I fear that I have a bad wire in the harness. I have 12V on the purple wire on the female side of the harness. I want to simply run a new 12v over to the coil. I plan to swap out the coil with an internally resisted coil. The one on it now says it needs to have an external resistor (Which for the life of me I cant find). I am attaching a picture of the wiring diagram that show the connection I want to cut and the connection I want to add. Can anyone weigh in on this?
