chrismurr1
- Joined
- Jan 27, 2011
- 41
first off, im new to iboats.com but not new to boats or engines. I have been a guest on the site for some time and i look forward to hopefully getting some help from the many experts i see here.
history: 1975 33' Chris Craft Sportfish with twin 1984 Merc 5.0 (305) engines, Borg-Warner 1:1 trans straight inboard, closed cooling. both engines have good compression 155-165, thuderbolt IV ignition systems. New remanufactured Q-jet carbs 600cfm mounted on a wedge plate to keep them level. both engines are on new electric fuel pumps and currently fed from a new 12 gal fuel tank (getting original ones replaced). new Merc water separating fuel filter and new in line filter (right before the carb). port engine has stock merc q-jet intake, starboard engine has edlebrock aftermarket q-jet intake. Boat is in water.
Problem: Starboard engine wont idle on the idle circuit. i have double checked to assure that the circuits are not clogged with anything. i have the idle mixture screws at 4 turns out at the moment, however, to get it to idle well (950-1000 rpm) i need to have the idle speed set screw in all the way (which of course takes it off the idle circuit I believe). the engine idles a little rough at 800 in gear.
timing at 950 RPM is 8 degrees BTDC if i can get it to idle down at 700 its roughly 6 BTDC. the idle mixture screws can be closed at this point and have no affect which i am sure means im running on the cruise circuit. when i try to lower the idle speed screw RPM drops to roughly 500 and i cant stabilize it, even had the idle mix screws out to 6 turns but got nothing and if finally dies.
i did make a couple observations..... these new carbs are electric chokes, not hooked up yet and set very lean, almost all the way open. (i do warm the engine up to operating temp before trying to get the idle set right). the vacuum pull off on the starboard engine looks like it gets pulled back all the way when cranking (damn good vacuum) but the port engines pull off barely moves till the engine starts.
also i cant seem to fine any vacuum leaks at the intake or leveling wedge using starter fluid to see if the rpms jump.
the port engine is set to a 950 idle (800 in gear) with a 10 degress BTDC timing with the idle speed screw about half way in.
nether engine blows smoke or smells fuely at the exhaust.
sorry for being long winded but i know more detail is better when asking questions.
