5.0 mercruiser efi stalling
rskeeters
A friend of mine(truly a friend of mine, I can't afford a 2000 sea ray) has a 2000 sea ray with a 5.0 mercruiser efi. While boating on the river at cruising speed, he abruptly pulled the throttle back to idle, and maybe into reverse to avoid hitting a log. Now the boat will stall whenever you move the throttle to idle swiftly from about any setting. Any thoughts?
Thanks in advance for the input
tommays
Re: 5.0 mercruiser efi stalling
You will need to give more info about the motor AND drive the serial # of both would be best to get the help you need in soveing your problem
Tommays
