TheBlizzard
Thread starter- Joined
- Nov 20, 2010
- 48
Ok so the boat in question is a 1989 Celebrity 20' Cuddy with a 5.0 Merc/Alpha 1.
First problem is that I think I have a small oil leak somewhere, I replaced the main bearing last year thinking that was the problem but it is still leaking a little bit. Basically I can use the boat for 6 hours before it loses even a half quart. I think it may be one of the valve covers but I am not sure. I already checked the oil pressure sending unit and it was perfect.
Second problem happened this last weekend. I had the boat out for a little cruise, came back in and went to raise the drive and it wouldn't go up. It didn't even make a noise trying to go up, it would buzz when I lowered it, but it was alll the way down so it wasn't moving. It was late so I said screw it and would look at it the next day. When I went to put it on the trailer and drove the boat it forwarded just for a second it started to work normally again. What the heck? Just a fluke? Or did the drive get stuck?
Third thing is this: I went to start the boat in the water at the dock last weekend and it wouldn't start, it wouldn't do anything for that matter. I had good power from the battery but nothing in the boat had power. I tried to reset the 50amp break on the top of the motor and that did nothing. I went to get my trailer to take it out of the water and when I went back in the boat it started right up? Another fluke thing I cannot put a finger on? Is it that main relay going bad? Starter solenoid?
I am stumped, any help would be appreciated.
