5.0 TKS closed cooling plugs
RussGT209
I have a 2009 5.0 I discovered one of the blue plastic cooling drain plugs in the bilge and cannot find a home for it. I have found 5. Block and manifold on either side, and one on the elbow coming out of the water pump. Any help much appreciated.
Russ
RussGT209
Thanks for the reply. I don't seem to have a fuel cooler. Am i correct that the PS cooler is in the attached, the part with the hose clamp on the left? This is in the back of the engine compartment and impossible to see, i reached back with my phone to get the picture m
RussGT209
I've been seriously considering that one was dropped during installation and has been rattling around. My coolant is full, I have run up to operating temperature at the berth with no signs of leakage, but have been afraid to take it out.
Yes the item on the left is the power steering cooler
fetch
Could use your serial number to help verify because I am unable to find a 5.0 with closed cooling at BAM. Look on the port side down low following the hose coming from the PS cooler to the heat exchanger. There should be another a tube with a fitting to be drained during winterization. I don't see the hose in this pic
fetch
RussGT209
Thanks, serial number is 1A341817, and it has a San Juan Fresh Water Cooling System Kit #MC-340
OK, that makes since with your S/N. Think your right, it was dropped and just now found
RussGT209
Perfect, thanks very much for the help, I'll pack along a few bottles of fresh water, and go for a cruise!
