5.0 Volvo Penta GXI rough idle and knocking
muc
"Retired" Association of Marine Technicians...
Thanks for the serial number, makes it so much easier for me.
The picture you posted of the fuses. From left to right --- 20 amp fuse for starting circuit, 50 amp circuit breaker for trim, 40 amp fuse for dash panel. You don't have a "main" circuit breaker on this engine.
At this point you have a "cranks but doesn't start" and you have found no spark.
On this engine there are a number of things that can cause no spark.
first check if you see a reading on the tachometer when your cranking the engine. What is it?
next check the ignition fuse in fuse box, it will be one of the smaller fuses.
Your ignition system caused problems for mechanics who weren't properly trained on it when it first came out. A lot of parts were replaced that didn't fix the problem and a few engine computers were ruined when people put jumper wires where they shouldn't. Or used troubleshooting equipment and methods from earlier systems. Got so bad Volvo came out with a service bulletin that does a very good job of walking someone through the tests without requiring them to understand how the system operates.
I suggest you ask your Volvo dealer for a copy of it. Or search the internet and see if anybody has posted it. The agreement I have with Volvo Penta doesn't allow me to post it.
Service Bulletin 28-1-6 published 05-2014
it starts out,
The following information applies to port fuel injected IAFM engines (2001 and up) that use a MEFI or EGC engine controller. The ignition coils on these engines have a heat sink and ignition module mounted to the coil assembly. The symptoms of this failure are a crank but no start condition. Preliminary troubleshooting should be performed to fuel and mechanical systems to be sure they are functioning correctly and that a weak spark or no spark condition is suspected. The procedure that follows is an on-engine test of the ignition coil.
P.S. You have an IAFM engine with EGC controller.
edit; I should add. If you do decide to use this service bulletin, you have to remember that it was written for people with limited knowledge of how the system works. So you must follow all the steps in the order they are written.
muc
I installed the new CPS and had no affect. Still cannot get it started. I pulled a plug to see if I was getting spark. No spark to be found.
Missed this when I posted. What did the vanes on the reluctance wheel look like? Where did you get the Sensor?
muc
muc the tach registers maybe 100 briefly and then 0 while cranking.
ignition fuse is good
Not a good sign.
Without a scantool, I suggest you try to get a copy of that service bulletin and check the ignition system.
dschnacky
muc I'm having the worst time trying to find specific information pertaining to my specific engine model. One thing I did tonight, I went out and with the key in the on position, I connected to the distributor wiring plug and am getting 5V there. Seems strange.
I also disconnected the high tension line from the coil and cranked the engine running that line to ground and am getting spark but it is WEAK. Obviously weak enough that I'm not able to visibly see spark coming from the distributor via plugs.
All the manuals talk about the purple wire from the coil and testing for 12V there. I don't have a purple wire at all. I'm thinking about swapping out the coil anyways but really would like to troubleshoot it first if possible. I ordered this: https://vod.ebay.com/vod/FetchOrderDetails?itemid=401757294356&transid=880156426027&ul_noapp=true. Hoping it'll help
muc
https://www.volvopenta.com/marineleisure/en-en/for-owners/your-engine/manuals---handbooks.html
If you click on the above link, it will take you to where you can get the correct manuals. Put your serial number in and click search. All the manuals for your specific engine will show up.
Not sure what manuals your looking at that talks about a purple wire to the distributor. But they aren't the right ones.
The computer controls the ignition on your engine. Without a scantool there is very little that you can test. The ignition system is one thing that you can test, but i fear that you will cause more problems if you do it wrong. That's why I suggested the service bulletin.
Parts swapping is usually a a bad method for troubleshooting, especially if the parts your using come from anybody other then Volvo. Swapping out with aftermarket parts has a better chance of making things worse.
Have no idea what you ordered from eBay. That link only works for the person who placed the order.
dschnacky
muc solid reminder on OEM Volvo products. I have a genuine Volvo EFI diagnostic manual coming from ebay (that was the link). I replaced The ignition coil/module/heat sink with new Volvo product. No change.
I’m done part swapping now :) So I checked the voltage with key on at the CKP and it’s 4V. Seems to me that it is supposed to have B+ (12V min), right?
Same is true for the CMP wiring plug at the distributor.
The starter solenoid intermittently seizes and gives that lovely click almost as if the battery is undercharged. Battery is fully charged. Wondering about the starter relay. Would that have the ability to cause low/no voltage to the ignition system?
muc
Those are 5 volt sensors. Anything below 4.9v is bad and must be corrected. Could be battery, wiring or one of the other 5v sensors causing it.
dschnacky
UPDATE:
I was finally able to get it into a certified VP shop. I found a couple other posts on here with MAP sensor issues. Well as it turns out. The MAP needed to be replaced as well as the (what I'm calling the CAM sensor) beneath the distributor. Both of those sensors replaced (along with my tuneup and starter motor replacement) and the boat is running like a top!
Had her out on the Mississippi the other weekend and heading back out tomorrow.
So as a rundown:
I was slowly moving in gear when it first stalled. Could NOT get it restarted. Opened the engine compartment and the bilge was full of water. Turned the bilge pump on and pumped it out while getting towed in. The bilge housing was broken likely from being winterized full of water.
Got it trailered and took it home to dry it out and replaced the bilge pump. Did a full tuneup, plugs, wires, rotor, cap. Able to get it to start but did NOT sound great. Intermittent stalling at idle, intermittent no start, stalling when putting it in and out of gear.
Replaced starter motor assembly as it tested bad and was starting to fail. Replaced ignition coil assembly which I still have as that did not resolve the issue. Wasn't getting spark still.
The FIX was the MAP and CPS sensor as both had failed but they weren't throwing codes.
At any rate, I hope this resolution helps anyone else out. I'm happy to salvage the rest of my boating season.
Cheers,
Danny
muc
Thanks for the update. Glad they got you back on the water. Two sensors failing at the same time is rare. But when it does happen it can be difficult to troubleshoot.
