firebird1158
Thread starter- Joined
- Oct 13, 2008
- 97
I have a 1998 Doral 300SE with twin VP 5.0GI engines and was checking oil levels and noticed one had too high oil level but looked and smelled fine. I was thinking someone overfilled it as boat is new to me this season and couldn't remember what the level was when picking up boat, just remember it was clean...
Anyhow i'll give you some history, picked up boat and starter on this engine(port) was loud starting engine and slow, owner blamed low battery. I knew it was the starter dragging at worse worn teeth on flywheel(which i could live with and fix). Well after arriving home from my 12 hr drive with my new boat the problem seemed to worsen and refused to start a few times so i pulled the starter which was a little loose and found 2 broken teeth on ring gear. My biggest fear(at the time) because would have to pull motor. I tightened starter up and boat started again with the usual noise but noticed high oil level.
My intent was to just pullout some oil to get the level where it should be and recheck all guages(oil pressure and engine temps have all been good since getting boat).
Well I decided to give boat a good run and recheck again and everything looked the same too high on dip stick but clean and smelled normal.... So while oil is hot i wanted to pull some out but after inserting my new oil extractor it began to very slowly pump out very milky oil????
So now I am at a loss as to what has happened as the oil should be milky if there was water in the oil pan wouldn't you think? any ideas would be greatly appreciated as to how to proceed. Manifolds on both engines look almost new and owner even through in an extra set as he appearently keeps an extra set just in case....
