JJ Schnell
Thread starter- Joined
- Sep 22, 2018
- 19
Posted a thread a week or two ago about boat dying on the water and unable to restart. Can't figure out how to edit or update my posts so figured I would start a new thread with an update.
Engine does not want to start the last 2 times we took it out once it gets hot outside. Started fine in the morning when we headed out but even after we had drifted for a couple hours without it running it did not want to restart, about 95 outside right now, was about 105 the other day.
Checked and was getting fuel to the carb when I went WOT with engine off. Finally got it to start today after 4 or 5 attempts today, never did get it started the other day and had to be towed. Had to crank it for a good 9-10 seconds before it fired up. Don't think, although not 100% sure, it's vapor lock as when it happened the other day I cooled off the pump and fuel lines with water and tried starting for almost 2 hours off and on and still wouldn't fire.
Engine only has 240hrs on it and the boat is a 2008 so not terribly old. Fuel is non-ethanol 91 octane. Dual batteries, tried to start with each and then both with same results.
I'm kinda leaning toward fuel pump going bad or possibly an ignition issue?
