Augoose
Thread starter- Joined
- Mar 21, 2010
- 1,245
So today we tried launching our carb'd boat, a '99 CC with the 5.0GLPWTR. Per our normal procedure (we've been out several times this year so far), I pumped the throttle twice and started the cold engine. Started normally and idled for about 45 seconds at which point the engine stopped. Did some quick troubleshooting at the ramp but eventually pulled the boat back out and went home.
Once home, I verified 12v at post #30 of the relay and then jumped #30 and #87. No sound whatsoever from the low pressure fuel pump. I then removed the wiring harness at the top of the fuel pump and got 12v there when the ignition switch is in the start position. Further, I pulled the cover to the fuel bowl at the carb and very little fuel dripped out - definitely not getting fuel to the carb. Sprayed a touch of starting fluid down the throat and the engine started instantly.
Seems to me that the fuel pump is bad, but I've read some threads which had the same symptoms as mine, including no function from the pump when jumping #30 and #87, yet they claim their issue was the anti-siphon valve in the tank? I felt confident enough to order a new fuel pump along with the two o-rings, but while I'm waiting I just wanted to run the scenario by the experts.
Thanks in advance for responses.
