5.0l mercruiser wot max rpm range?
rinoturd
just moved to 6000ft elevation with my sea level geared ebbtide 5.0 merc alpha one. what is the norm wot max rpm engine on the boat that i dont want to exceed when i reprop to adjust for the altitude. any other suggestions for maximizing performance. also just pulled the 2 freeze plugs on the block 2 plugs on the manifolds and one below the water pump. drained the water, replaced the plugs then pulled the hoses off the thermostat housing and added bio antifreeze, fooged the carb and added fuel stabilizer. anything i missed with the winterizing? thanks.
Re: 5.0l mercruiser wot max rpm range?
Ayuh,........
If you set it up to run 4200/4800rpms,........
It'll be Right where you want it..........
achris
More fish than mountain goat
Never 'winterized' my boat.... use it all year round :D:D:D:D
A couple of models of those engine were speced at 4600-5000rpm WOT....
Chris.........
